Cprint
serial validation
I would like to use the serial validation tool for our software release. We plan on using the user-defined validation option. For this option, we would like to add the name and organization as parameters in our function call. Is there a known way of doing this?
Cosmin
This can be done by using the properties of the "User Name" and "Organization" edit controls. These properties are USERNAME and COMPANYNAME and you can access them by using the MsiGetProperty function.
You can read more about this here:
http://msdn2.microsoft.com/en-us/library/aa370134.aspx
Cosmin
Cprint
additional properties
We need the property of the name(installation name) in the title bar. Is there an easy way to get this?
Cprint
The property labeled "ProductName" works.
Return to “Feature Requests”
