jmedina
Questions
1.- How to Custom Dialog for Uninstallation via Add / Remove Programs?
How to Customize dialog "Do you want uninstall this product" Yes,NO , how can add product name in this dialog
2.- Install in UNC path a demo make in AI
when try uninstall a product (msiexec /x {GUID}) and if the machine is off line can't uninstall a product?
MSI (c) (58:94) [17:34:31:751]: Doing action: CostFinalize
La acción se inició a las 17:34:31: CostFinalize.
MSI (c) (58:94) [17:34:31:751]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (58:94) [17:34:31:761]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (58:94) [17:34:46:292]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (58:94) [17:34:46:292]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (c) (58:94) [17:34:46:292]: PROPERTY CHANGE: Adding Datos_DIR property. Its value is '\\vmxp1\DATOS\'.
MSI (c) (58:94) [17:34:46:292]: PROPERTY CHANGE: Adding Datos1_DIR property. Its value is '\\vmxp1\DATOS\Datos1'.
MSI (c) (58:94) [17:34:46:302]: PROPERTY CHANGE: Adding NetDir_DIR property. Its value is '\\vmxp1\DAC\NetDir'.
MSI (c) (58:94) [17:35:24:346]: Note: 1: 1314 2: \\vmxp1\DATOS\
MSI (c) (58:94) [17:35:24:346]: Note: 1: 1606 2: \\vmxp1\DATOS\
Error 1606. No se puede obtener acceso a la ubicación de red \\vmxp1\DATOS\.
MSI (c) (58:94) [17:35:29:934]: Producto: Prod-COM -- Error 1606. No se puede obtener acceso a la ubicación de red \\vmxp1\DAC\Sistemas\COM6.00.
3.- How to uninstall this demo, if the directory doesnt exist.
Re: Questions
This is a predefined Windows Installer dialog and cannot be changed from you project.
Please note that you cannot uninstall the product if the machine is offline. System changes cannot be performed on the machine if a connection to it its not available
or the machine is completely turned off.
The uninstall process will work correctly if the directory doesn't exist. The problem appears when Windows Installer doesn't have access to that location/path.
Even if the location doesn't exists anymore Windows Installer must still have access to it.
