R.Mueller
Installing SharePoint Solution always fails
I have created a new SharePoint Solution setup project with Advanced Installer 10.3. I tried this a couple of times (with the wizard, starting from an empty enterprise project, ...). When I try to install the project on a system running SharePoint 2010 (in this case Foundation only), it only shows me this message box:
The project was creating with importing a wsp solution with the wizard. I have set the following options with the wizard:
  • Allow Global Assembly Cache (GAC) deployment
  • Overwrite files created by other solutions
  • Deploy globally & Deploy immediately
  • Start SharePoint administration service during install
  • SharePoint Foundation: 2010
  • Run only if user has permissions for deploying SharePoint solutions
If I remove the "Run only if user has permission for deploying SharePoint solutions" option, the setup will start, but fail later during installation.
I have tried to install the underlying wsp package manually with Add-SPSolution (with the same user account), this works as expected. So I am sure, this message is not correct.
What have I done wrong? Is there any special trick?
Roland
R.Mueller
Re: Installing SharePoint Solution always fails
A similar question was asked here, but without answer: http://www.advancedinstaller.com/forums ... =5&t=25899
Roland
Hi Roland,
I am not sure why you encountered this behaviour. I've tested your scenario but I cannot reproduce it.
Can you please try to see if the current user is in the WSS_ADMIN_WPG group? If it is not can you please try to add and see if the behavior still persist?
Please let us know if that helped, otherwise give us more details.
