UnChanter
x64 Custom Action not called
ello all!
I created 2 wix custom action for installer (A and B dlls)
- A compiled as a Any CPU target platform
- B compiled as a x64
A worked correctly, but B is not called
In task manager I have follow:
first msiexec.exe is a installer process
second is a process for custom action
Also I tried to compile B custom action as a exe file and run it. And have a follow error:
How run custom action compiled for a x64 platform?
Re: x64 Custom Action not called
A number of msiexec processes can be running during an installation. The reason for this is that Windows Installer uses a client-server model for performing installations.
Additionally for security reasons, Windows Installer hosts DLL and script custom actions in a "sandbox" process.
Depending on how the install was initiated, one of the msiexec processes can be the client process and the other one is a Windows Installer service.
By the way, why would you need a x64 custom action? Please take a look on the Options to integrate and debug custom actions article where you can see how to debug DTF C# custom actions.
UnChanter
Dan wrote: By the way, why would you need a x64 custom action?
I need to use third-party library compiled for x64 platform.
