UnChanter
Losing file when upgrade
I have two setup file v1 and v2 (for example).
When I install v1 it's work, when I upgrade to v2 installer doesn't install file (in my case System.Web.Razor.dll)
But when I remove v1 via control panel and install v2 installer install this dll
So the question, why?
Anton
Re: Losing file when upgrade
Hi Anton,
Usually, this behaviour occurs when performing an upgrade for versioned files (e.g. .DLLs, .EXEs, etc) when the file from the destination folder has a higher version than the source file.
If during an upgrade operation there are files missing from the installation folder, then the next step to troubleshoot this is to create a verbose log of the installation process.
If you can find the following message: Disallowing installation of component: GUID's component since the same component with higher versioned keyfile exists in your log, then this is the reason why your file is not coppied on the target machine.
The upgrade process performs the following actions:
  • Detect and completely remove older products. During this operation the file will be removed from the machine.
  • Install the new product. The file from the upgraded version will not be installed since its component was not marked for installation.
To overcome this behaviour, you can enable the Always overwrite existing file option from the File Operations Tab of the File Properties.
Please let me know if this is your case too.
UnChanter
when I run command
msiexec /i <path_to_msi> /L*V <path_to_log>
I have follow error:
I compare by contents two dlls (old and new) and they are identical!
Update
I create log via
"C:\MyPackage\Setup.exe" /L*V "example.log"
and have two records
MSI (s) (48:9C) [16:24:18:722]: Disallowing installation of component: {EEB8508A-C441-47F5-9A64-35A629271DC2} since the same component with higher versioned keyfile exists
MSI (s) (48:9C) [16:24:18:738]: Disallowing installation of component: {89F382AA-BBF7-490D-A15C-5D3CAD42D207} since the same component with higher versioned keyfile exists
I turn on overwrite option for this file.
Thanks a lot!
Anton
You're welcome Anton,
