dorukar
2 cabs 1 media
Hi all,
I am a new AI PRO user and want todeploy a dictionary project.
The project has a part that 70000 files are under same directory. I know that 64k files are allowed for one cab, so I produced 2 cabs by using multiple volumes section.
However when I write the project to CD, the installation wants me to insert disc 2. How shall I overcome the problem.
Thanks for your assistance...
Doruk AR
CENG
Ionut
AI does not currently support assigning the same volume label when creating multiple volumes. I have added this on our TODO list and it will be available in a future version.
As a workaround, open the built MSI package in Orca, select the Media table in the left list, and set the same "VolumeLabel" for all the records in the right list ("Disk1").
Ionut
Denis Toma
Advanced Installer Team
dorukar
Hi again ionut,
Your reply solved my problem, thanks to you and Orca.
Doruk AR
