burnersk
Make the "Limit to basic user interface" option also available with build options
I am creating a setup project with a single MSI installer, web installer, and Active Directory installer. The latter requires the option "Limit to basic user interface" to be set.
However, the option "Limit to basic user interface" is only available in the (global) "Install Parameters" section and would also affect single MSI and web installer, in which I do not want set the option.
Please move the option or add an additional checkbox for the option to the individual build sections.
Re: Make the "Limit to basic user interface" option also available with build options
Fortunately, it is already possible to do that.
In the "Install Parameters" page, you can set the options per-build. Let's consider you have the following two builds:
In "Install Parameters" page, you can set the "Limit to basic user interface (simple progress and error handling)" option for 1 build only, if needed. To do so, you should select the build for which you want the option to be applied from the "Build" section in the ribbon.
burnersk
Thank you very much, Catalin. Somehow, I have overseen it completely. It works great.
You are always welcome!
I am glad I was able to help.
Return to “Feature Requests”
