atanc
Check version of file in MSI using VBScript
I need to check the version of a file included in an MSI package that is being run, but am unsure on how to go about this. I have a "Launch attached file" custom action that runs a VBscript, which I think I can also use for this purpose? If so, how do I read the file version of a specific file within the msi? Are there any VBscript samples showing how to do this?
Thanks in advance,
Anthony
Re: Check version of file in MSI using VBScript
Hello Anthony and welcome to Advanced Installer forums,
As the MSI file is basically a database, you can open it and get the required information from it. In this case, you may want to look at the "File" table. The "File" table contains all the files and also their "Version" attribute.
Basically, what you need to do here is open the MSI database, access the "File" table and get the "Version" attribute for your file.
Unfortunately, we do not have a how-to for this (using VBScript).
However, my colleague Dan created a similar How-To by using a C# custom action:
MSI Open Database to get list of file paths to the installed files in a custom dll
There you can also find a sample project for it and also the .SLN file for the custom action, so you can inspect its' code.
In what regards VBScript, I am pretty sure you can find plenty of sample projects on the internet on how to do this.
atanc
Thanks Catalin, as long as I know Im on the right path by doing this via a Custom action script, I'm good to go.
Appreciate your help
Cheers,
Anthony
You are always welcome, Anthony!
I am really glad I could help.
