bottonTurn
Macafee detect a double extension file threats
Hi all,
When run a .EXE upgrade of the product Macafee detect a double extension file alert bellow the following path
C:\Users\<user>\AppData\Local\Temp\1\EXE5DA3.tmp.bat
Is this a file extracted by advanced installer? or someone recognize this file?
Diego
Re: Macafee detect a double extension file threats
Hello Diego,
Those .BAT files are temporary cleanup files.
We have fixed this issue (the double extension for the cleanup .BAT files) in Advanced Installer 16.1 (released on July 2nd, 2019).
bottonTurn
Thank for the information!
So, to know what I should to update, i have to move project schema .aip or the installed version in our build servers?
Hello Diego,
If the "build server" is the machine where you build your project, then the newer version of Advanced Installer should be installed on it - so you can build your project using the newer version of Advanced Installer.
bottonTurn
Hi Now an other user report a similar alert but in this case with windows defender,
Do you recognize this file
Is this an other issue in old AdvancedInstaller builds?
At a first glance this seems to be a resources used by a custom action of your setup project and cached by Windows Installer during installation. Not sure which resources though.
Could you replicate this issue consistently? The only way we could investigate on this will be to replicate the behavior on a test machine. So, if you manage to find out any test case or pattern that replicates this behavior just let us know.
