Zsolt Kollarits
SignTool error while trying to build our exe
Since we upgraded our .aip project from 18.9.1 to 19.3 we are not able to build our .exe file any longer due to this error here:
The digital signing of the APPDIR\CefSharp.BrowserSubprocess.exe file failed. Error message: 'Done Adding Additional Store
Number of errors: 1
SignTool Error: The specified timestamp server either could not be reached or
returned an invalid response.
SignTool Error: An error occurred while attempting to sign: C:\Users\ZSOLT~1.KOL\AppData\Local\Temp\BUIEE1C.tmp\AFT7DCB.exe
This is an unknown "signtool.exe" error!
For a possible solution please check our Digital Signature FAQ from:
https://www.advancedinstaller.com/user- ... ature.html '
Advanced Installer 19.3 build c4fcfe53
*** Stack Trace (x86) ***
[0x769bb922] RaiseException()
[0x021ad8fa] -----
[0x00f2c2fb] -----
[0x00f29785] -----
[0x00f2948e] -----
[0x01102c84] -----
[0x01902026] -----
[0x00f23383] -----
[0x00f23251] -----
[0x01043bdb] -----
[0x011be3eb] -----
[0x00d01847] -----
[0x00b6a297] -----
[0x009daf83] -----
[0x01902a88] -----
[0x77da5dce] RtlAllocateHeap()
[0x769a322b] FlsGetValue()
[0x021b0107] -----
[0x021acde9] -----
[0x009f086e] -----
[0x75f0fa29] BaseThreadInitThunk()
[0x77dc7a7e] RtlGetAppContainerNamedObjectPath()
[0x77dc7a4e] RtlGetAppContainerNamedObjectPath()
[0x006f0000] MODULE_BASE_ADDRESS
Could you please take a look at it and suggest us something?
Thank you in advance.
Zsolt
Re: SignTool error while trying to build our exe
Hello Zsolt,
Can you please have a look on the following forum thread which debates a similar issue: Signtool file in use error when creating exe
In your case it looks like the problem is with the Temp folder. Can you please verify if an antivirus/anti-malware running in the background or the Windows Defender may be restricting access to the files in the Temp folder?
Hope that helps!
Zsolt Kollarits
Hi Liviu,
Thank you, it seems the timestamp server was down, so our setup is working now. :)
Zsolt
Hello Zsolt,
Yes, in the last few days the timestamp server (http://timestamp.digicert.com) was down. That also affected our build operations.
When the timestamp digicert server is down, you can use any timestamp server from our predefined list or you can add any server that you want to be used:
Please let us know if there is anything else we can help you with.
Zsolt Kollarits
Hi Liviu,
Thank you for your answer, our timestamp server is up and running now, so we don't experience any issue with our setup anymore.
Zsolt
You're welcome, Zsolt!
I'm glad everything is working as expected now.
