zick
Features greyed out - trial version
Screenshot 2026-04-07 160644.png (12.1 KiB) Viewed 9553 times
I am trying to test the trial version to determine if it is worth buying but running into certain things that are greyed out.
I've opened an existing MSIX file and changed the Installer Project type to Architect figuring this would give me all functionality.
But when I navigate to Declarations, I can neither delete an existing declaration (delete option is greyed out) and trying to add a new declaration is also all greyed out?
Screenshot 2026-04-07 160715.png (35.69 KiB) Viewed 9553 times
Re: Features greyed out - trial version
Hello Grant and welcome to our forums,
If possible, could you please share with me a download link for the MSIX package that you are trying to modify (by email at support at advancedinstaller dot com)?
I would like to run some more tests on my end and see if I can find the culprit here.
zick
Hello Catalin,
The MSIX package that I am trying to modify is one that we made by converting an In-house created exe application into MSIX using Microsoft's MSIX Packaging tool.
Don't know if that's part of the problem or not?
Hello Grant,
Apologies for the quite delayed reply on this - we had some days off thanks to the Orthodox Easter.
Mhm, that should be a problem here, no.
If possible, could you please share a download link for that MSIX file with me (by email at support at advancedinstaller dot com) so I can run some tests on my end?
