aweber
Error 1001 during upgrade
This error only happens during an upgrade of a previous version of my application...
The install log says:
An exception occurred while trying to find the installers in the (MYASSEMBLY) assembly.
System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
My Installer class in my assembly has not changed in a very long time (many versions). The package appears to include all my dependencies (but I have not figured out precisely the one that it thinks is missing -- how do I determine this?).
The major difference is that in my previous version my package/assembly used .Net 4.6.2, this one is packaging and using 4.7.2. Could the uninstall/upgrade part be tricked by the .Net difference?
Please advise asap. We are unable to distribute our new version until this is fixed.
EDIT: It is likely this is during the "UnInstall"...how can I ensure AI runs my Installer Class's uninstall code BEFORE uninstalling all the dependencies? (Like virtually first.)?
EDIT2: The previous version uninstalls cleanly if I just choose to uninstall it from control panel. The new version installs fine if it is a "fresh install" (no previous version found). The issue is only during "Upgrade".
