Steve Shannon
How do I set a folder to Hidden
Can anyone help?
I need to set a number of folders included in my install as hidden. I cannot see anyway to do this.
Any help would be appreciated.
Cata
The only way to do that is by a custom action. Windows Installer does not support attributes for folders, only for files.
Mike
Here is an example of a VBScript that sets the Hidden attribute for the Application Folder.
Function MakeFolderHidden()
   Dim filespec
   filespec = Session.property("APPDIR")
   Dim fso, folder
   Set fso = CreateObject("Scripting.FileSystemObject")
   Set folder = fso.GetFolder(filespec)
   folder.attributes = folder.attributes Or 2
End Function
This custom action should be of immediate type, otherwise the installer cannot access the APPDIR property.
It also should be scheduled at a time the folder has been created already. The InstallFinalize standard action is such a place.
Note: If you are using a version older than 3.4 replace APPDIR with TARGETDIR in the above script.
Mihai Bobaru
toyito
Hi
Im really interested in use this script bu i dont kwon how, woul u give more details pls
Hector
Ionut
Follow the steps below:
1. Create a new text file ("MakeFolderHidden.vbs") and copy the above function into it.
2. Switch to the Custom Actions page and select from the toolbar "Show Standard Action -> Before Finalization -> InstallFinalize".
3. Right click the "InstallFinalize" item and select "New Attached Custom Action", then choose the script file you created in step 1.
4. In the "Function Name" field enter "MakeFolderHidden" (without quotes).
5. Set the Execution Condition appropriately. For example, if the script should run when the application is installed, set the Execution Condition to: (NOT Installed)
6. This VBScript sets the Hidden attribute for the Application Folder. Thus, if you need to hide another folder, you should modify the script accordingly.
Denis
Denis Toma
HasNoName
Re: How do I set a folder to Hidden
I hope anyone can help me :)
I tried this one in the new version of AI, but it wouldn't work :roll:
I need the attribute "Read Only" instead "Hidden" because I will integrate icons in folders that includes desktop.ini, desktop.ico and I wouldn't use a batch.
What steps are required?
I use the script above. Support the newest OS this variant of VBS?
Thank you in advance :)
_
Teodor
Hello
You can use the same VB script and change only the folder attribute code to 1 for Read Only.
You can add an Execute inline script code custom action with sequence with the following properties:
- Action Data: [APPDIR]
- Script Type: Visual Basic script (*.vbs)
- Execution Time: When the system is being modified (deferred)
- Execution Options: check all (no impersonation)
- Execution Stage Condition: Install [x]
- Script Code:
Dim filespec
filespec = Session.property("CustomActionData")
Dim fso, folder
Last step is to move the MakeFolderHidden custom action under Install Execution Stage just before Finish Execution action group.
I've attached a project sample with the MakeFolderHidden custom action.
AI f545 sample.zip
(2.73 KiB) Downloaded 1273 times
This project was tested successfully on Windows 8.
Best regards
Teodor Micu - Advanced Installer Team
HasNoName
Thank you, it works very fine :) 8-)
Can per script added more attributes? (read, hidden, ...)
But why read only instead system for folder icons?
_
Teodor
Hello
Of course, you can set multiple attributes with the same VB script like this:
folder.attributes = folder.attributes Or 1 Or 2 Or 4
This example will set three attributes: Read Only, Hidden, System.
I'm afraid I don't understand your question. Can you give more details about what you want to achieve?
Best regards
HasNoName
OK, thank you.
I mean, why does this works only with Read Only attribute and not with System attribute to see the folder icons and some information of desktop.ini? :) I mean, many years ago, this was still working with the system attributes in Windows :?
A question. How can I set a file attribute e.x. desktop.ini file that was imported in AI?
_
Teodor
Hi
I'm afraid it's unclear what you mean by "this". Maybe the article How to Customize Folders with Desktop.ini could help you.
Windows Installer has support for setting properties on files. In Advanced Installer go to Files and Folders page, select the file(s), press ENTER and from the File Properties Tab and select the file(s) attributes.
Let us know if you have other questions.
Best regards
dsadsadsa
I've foud this topic.
It's a little bit old, but I'll try.
I have to hide 2 folders added in the system during an installation.
I have used the script here above to test with one folder and it's working like a charm.
Now that I would like to hide also the second one I don't know how to do it.
I've tried to add another script with the name of the second folder ( plus the "_dir")
But it's not working at all.
Anyone could help me, please?
In order to achieve what you want, we can proceed as it follows:
Dim filespec
Dim fso, folder
Dim dataArray
dataArray = split (filespec, "|")
for each x in dataArray
Set folder = fso.GetFolder(x)
Next
Where the "Custom Action Data" field looks like this:
[APPDIR]|[test_Dir]
The above script should set the hiddent attribute for both APPDIR & test folders.
