mhubel
arguments for prerequisite installer
We are trying to install LibreOffice as a prerequisite. If only a URL is specified, it works. If in addition I try to specify the command line such as:
msiexec /i LibreOffice_25.2.7.2_Win_x86-64.msi
on the Command line (Full UI) line, the msiexec installer just shows it's allowed call arguments and does nothing, The desire it to do this with an argument:
msiexec /i LibreOffice_25.2.7.2_Win_x86-64.msi ISCHECKFORPRODUCTUPDATES=0
It seems that the msiexec wants an absolute path. If that is the problem, is there a way to give it the absolute path where the file was downloaded to?
Re: arguments for prerequisite installer
If you add the MSI for LibreOffice in the "Prerequisites" page, then you do not need to pass the command line msiexec /i to that, because we do that automatically.
Instead, you only need to pass the extra arguments. So if the entire command line looks like this:
msiexec /i <path_to_msi> some_extra_arguments_here
in the command line field you only need to pass this:
In your specific case, you only need to pass this:
mhubel
Thanks for the suggestion. That did allow the install to complete but it only seemed to work with one argument. When I tried two, it still failed. So that was the good news. Then the LibreOffice does not seem to reliably honor the argument anyway so all this is a bit academic at the moment.
You are always welcome!
Glad to hear it worked.
Regarding the second parameter, that should also work, as the installer can receive more than one parameters - make sure you have passed them correctly.
For example if the parameters you are passing are like this:
param1 param2
try to also run the prerequisite manually from the command line using the same parameters, e.g.:
msiexec /i <path_to_installer> param1 param2
