harmn1
ACCESS VIOLATION after AI 7.3. upgrade
Dear all
I upgraded my AI to 7.3 from 7.2.1 this morning. The 7.2.1 projects load into 7.3. OK, but every time I try to save, it throws an ACCESS VIOLATION error (see screenshot) and deletes the AIP file (attached).
Can you please advise
Regards
Nick
iXAMiner.aip
AIP file (7.2.1 version)
(171.8 KiB) Downloaded 282 times
Error Message
Error Message
GabrielBarbu
Re: ACCESS VIOLATION after AI 7.3. upgrade
Thank you for bringing this to our attention.
This appears to be a recently introduced bug. We have spotted the issue and a bugfix will be available with the next version of Advanced Installer.
In the meantime I have attached a fix. Copy the attached UI.aip to the following location:
<Advanced Installer Folder>\themes\classic\fragments\
You will be prompted to overwrite the existing file. Choose "Yes".
Gabriel
UI.aip
(75.49 KiB) Downloaded 404 times
Gabriel Barbu
Advanced Installer Team
harmn1
Many thanks - that seems to work fine.
NIck
