jm2008
Error in License module
I use AI license module, the problem is that when the trial dialog appears on the user's machine, it doesn't give them option to try the software!!!!!! only one blank window saying you have 14 days trial, then Next / Finish button
There is something wrong with this window!! Any help!!
Cosmin
Re: Error in License module
This happens because your application doesn't use a common controls manifest (Microsoft.Windows.Common-Controls version 6.0). Perhaps this article will help you.
Cosmin
jm2008
Thanks for your reply,
But I'm using VB.net with VS 2005 -- The article you sent me is related to MFC?
Is there is any setup I have to implement in my application in order to display the license Dialog box? I checked the User Manual for the License Module, it mention nothing related to additional manifest files?
Cosmin
I mentioned the article because it contains details about what to use in the application manifest. You can find a full manifest example here.
Yes, you need to include a manifest which makes your application use Microsoft.Windows.Common-Controls version 6.0.
This is because most applications already use these manifest entries.
Cosmin
belsonmarble
Oops, 404 Error! That page can’t be found.
Thank you for bringing this to our attention. Just fixed the invalid link.
