Laurin
Address access violation
Hi guys,
It's a little deflating.... just extended the maintanance plan for advanced installer and the program seems to corrupt my project file. Everytime i want to save the file the following error appears. Even if i completely restart the advanced installer the error retains. Can you please help me as soon as possible? I'm in a little hurry and it tooks me some hours to make setup this installer project so i'm absolutly not in mood the make everything again!
kind regards
laurin
Cosmin
Re: Address access violation
Hi Laurin,
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it?
Cosmin
Laurin
Okey i'll send you the file at your support address.
thanks.
kind regards
laurin
Return to “Feature Requests”
