srini
Building/Installing problems
I managed to successfully build installers several time using the attached aip file. Just before publishing I checked in my aip script to our Document Control system and then repopulated and tried to build the installer. I get an error "Exception - Reason: Exception - Could not create cabinet file". I have attached the screen shot of the error as well. What is wrong?
ModularTest.aip
(165.86 KiB) Downloaded 506 times
GabrielBarbu
Re: Building/Installing problems
We've successfully built the package on our machines. This seems to be a problem related to your particular build environment. Perhaps there is not enough disk space or you do not have permissions to write to that location. You could try this on another machine and see if the behavior still occurs.
Gabriel
Gabriel Barbu
Advanced Installer Team
srini
Hi Gabriel,
You are right. I had run out of disk quota. Thst is sorted now.
