Frode
Windows 7 and Upgrade w/Install new version first
I just tested upgrade of our app in Windows 7, install built with AI 7.5, and got an error message from Windows/MSI.
Log enclosed, the installation was done on a Norwegian locale. An english translation of the error message would be something like
"Another version of this product is already installed. Installation of this version can not proceed. If you would like to configure or remove the existing version of this product, use Add/Remove programs in Control panel"
Installation/upgrade in XP work as expected.
Could someone please have a look at this, and promote it to a bug report if necessary.
-frode
ai.log
upgrade failure
(13.86 KiB) Downloaded 336 times
GabrielBarbu
Re: Windows 7 and Upgrade w/Install new version first
I am not sure why you are encountering this behavior. Please send your .aip project file to support at advancedinstaller dot com so we can investigate.
Gabriel
Gabriel Barbu
Advanced Installer Team
