jmedina
Slow setting path to folders
Hello
I've a installation proyect that contains a browse dialog, in this dialog I have an event:
setTargetPath = MY_TARGET
where MY_TARGET is a path selected by the user
when I click the next button this event is executed, this process take over 3 minutes setting path to folders
why is very slow ? :?:
This is a extract of the log file:
MSI (c) (24:28) [11:18:15:645]: PROPERTY CHANGE: Modifying Perfiles_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Perfiles\'. Its new value: '\\LIB-JMJE\DACTMP\Perfiles\'.
MSI (c) (24:28) [11:18:17:427]: PROPERTY CHANGE: Modifying APPDIR.EC2AB4C5_516B_4548_BF87_D69EA75B1760 property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Perfiles\'. Its new value: '\\LIB-JMJE\DACTMP\Perfiles\'.
MSI (c) (24:28) [11:18:17:447]: PROPERTY CHANGE: Modifying Centro_de_Asistencia_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Centro de Asistencia\'. Its new value: '\\LIB-JMJE\DACTMP\Centro de Asistencia\'.
MSI (c) (24:28) [11:18:19:510]: PROPERTY CHANGE: Modifying APPDIR.7666FB72_F521_48D8_A8BD_A21CDCC894AE property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Centro de Asistencia\'. Its new value: '\\LIB-JMJE\DACTMP\Centro de Asistencia\'.
MSI (c) (24:28) [11:18:19:530]: PROPERTY CHANGE: Modifying Extensiones_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Extensiones\'. Its new value: '\\LIB-JMJE\DACTMP\Extensiones\'.
MSI (c) (24:28) [11:18:21:613]: PROPERTY CHANGE: Modifying APPDIR.9367F355_1C74_40F3_A729_115E2CBE6C2C property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Extensiones\'. Its new value: '\\LIB-JMJE\DACTMP\Extensiones\'.
MSI (c) (24:28) [11:18:21:623]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\WINDOWS\
MSI (c) (24:28) [11:18:21:623]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\WINDOWS\Temp\
MSI (c) (24:28) [11:18:21:643]: PROPERTY CHANGE: Modifying Asistente_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Asistente\'. Its new value: '\\LIB-JMJE\DACTMP\Asistente\'.
MSI (c) (24:28) [11:18:28:271]: PROPERTY CHANGE: Modifying APPDIR.3EFD2B2E_937C_4814_8CBA_A7F19CC907A9 property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Asistente\'. Its new value: '\\LIB-JMJE\DACTMP\Asistente\'.
MSI (c) (24:28) [11:18:28:301]: PROPERTY CHANGE: Modifying Documentos_digitales_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Documentos digitales\'. Its new value: '\\LIB-JMJE\DACTMP\Documentos digitales\'.
MSI (c) (24:28) [11:18:28:392]: PROPERTY CHANGE: Modifying Deposito_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Documentos digitales\Deposito\'. Its new value: '\\LIB-JMJE\DACTMP\Documentos digitales\Deposito\'.
MSI (c) (24:28) [11:18:28:402]: PROPERTY CHANGE: Modifying TMP_AL_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-AL\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-AL\'.
MSI (c) (24:28) [11:18:28:412]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\DOCUME~1\Admin\CONFIG~1\Temp\
MSI (c) (24:28) [11:18:28:412]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\DOCUME~1\Admin\CONFIG~1\Temp\TMP-AL\
MSI (c) (24:28) [11:18:54:738]: PROPERTY CHANGE: Modifying APPDIR.DD83EBD6_040B_4B4A_BB1F_A35C2203E18C property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-AL\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-AL\'.
MSI (c) (24:28) [11:18:54:768]: PROPERTY CHANGE: Modifying Versiones_DIR.DD83EBD6_040B_4B4A_BB1F_A35C2203E18C property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-AL\Versiones\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-AL\Versiones\'.
MSI (c) (24:28) [11:18:54:788]: PROPERTY CHANGE: Modifying Respaldos_DIR.DD83EBD6_040B_4B4A_BB1F_A35C2203E18C property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-AL\Respaldos\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-AL\Respaldos\'.
MSI (c) (24:28) [11:18:54:788]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\Documents and Settings\All Users\Menú Inicio\Programas\
MSI (c) (24:28) [11:18:54:798]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\Documents and Settings\All Users\Menú Inicio\Programas\TMP\
MSI (c) (24:28) [11:18:54:798]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\Documents and Settings\All Users\Menú Inicio\Programas\TMP\Actualización en línea\
MSI (c) (24:28) [11:18:54:808]: PROPERTY CHANGE: Modifying TMP_Infoweb_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\'.
MSI (c) (24:28) [11:18:54:818]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\WINDOWS\
MSI (c) (24:28) [11:18:54:818]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\WINDOWS\Help\
MSI (c) (24:28) [11:21:22:244]: PROPERTY CHANGE: Modifying APPDIR.7103DED6_8F59_40C7_9262_4E56AC7DB0BC property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\'.
MSI (c) (24:28) [11:21:22:274]: PROPERTY CHANGE: Modifying AsociadoModelo_DIR.7103DED6_8F59_40C7_9262_4E56AC7DB0BC property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\AsociadoModelo\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\AsociadoModelo\'.
MSI (c) (24:28) [11:21:22:364]: PROPERTY CHANGE: Modifying DirPaquete_DIR.7103DED6_8F59_40C7_9262_4E56AC7DB0BC property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\AsociadoModelo\DirPaquete\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\AsociadoModelo\DirPaquete\'.
MSI (c) (24:28) [11:21:22:435]: PROPERTY CHANGE: Modifying AInternet_DIR.7103DED6_8F59_40C7_9262_4E56AC7DB0BC property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\AsociadoModelo\AInternet\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\AsociadoModelo\AInternet\'.
MSI (c) (24:28) [11:21:22:485]: PROPERTY CHANGE: Modifying Logs_DIR.7103DED6_8F59_40C7_9262_4E56AC7DB0BC property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\TMP-Internet\Logs\'. Its new value: '\\LIB-JMJE\DACTMP\TMP-Internet\Logs\'.
MSI (c) (24:28) [11:21:22:505]: PROPERTY CHANGE: Modifying Comprobantes_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Comprobantes\'. Its new value: '\\LIB-JMJE\DACTMP\Comprobantes\'.
MSI (c) (24:28) [11:21:22:515]: PROPERTY CHANGE: Modifying Programas_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Comprobantes\Programas\'. Its new value: '\\LIB-JMJE\DACTMP\Comprobantes\Programas\'.
MSI (c) (24:28) [11:21:29:193]: PROPERTY CHANGE: Modifying APPDIR.33D3FD4A_FB1E_4C5C_A192_98AC52065577 property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Comprobantes\Programas\'. Its new value: '\\LIB-JMJE\DACTMP\Comprobantes\Programas\'.
MSI (c) (24:28) [11:21:29:203]: Note: 1: 2335 2: C:\Archivos de programa\Archivos comunes\TMP\ 3: C:\WINDOWS\system32\
MSI (c) (24:28) [11:21:29:243]: PROPERTY CHANGE: Modifying SAE_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Comprobantes\SAE\'. Its new value: '\\LIB-JMJE\DACTMP\Comprobantes\SAE\'.
MSI (c) (24:28) [11:21:29:313]: PROPERTY CHANGE: Modifying Empresa_01_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Comprobantes\SAE\Empresa 01\'. Its new value: '\\LIB-JMJE\DACTMP\Comprobantes\SAE\Empresa 01\'.
MSI (c) (24:28) [11:21:29:353]: PROPERTY CHANGE: Modifying Bitacora_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Bitacora\'. Its new value: '\\LIB-JMJE\DACTMP\Bitacora\'.
MSI (c) (24:28) [11:21:29:423]: PROPERTY CHANGE: Modifying Logs_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Bitacora\Logs\'. Its new value: '\\LIB-JMJE\DACTMP\Bitacora\Logs\'.
MSI (c) (24:28) [11:21:29:583]: PROPERTY CHANGE: Modifying Sistemas_TMP_DIR property. Its current value is 'C:\Archivos de programa\Archivos comunes\TMP\Sistemas TMP\'. Its new value: '\\LIB-JMJE\DACTMP\Sistemas TMP\'.
MSI (c) (24:28) [11:21:29:583]: Note: 1: 2727 2:
Re: Slow setting path to folders
These operations are directly proportional with number of folders existent into your project and the
way they are structured. A high number of folder and subfolders will make Windows Installer to spend a lot of time
when checking them and making sure that all the installation paths are valid.
Can you please send us the aip files (the main project and the merge modules) to support at advancedinstalller dot com so we can analyze their folder structure?
