They may appear to have absolute paths but the project actually holds relative paths internally. The absolute paths to the files are displayed so that the files can be located easily by the user.
You can test this by renaming your project's folder. It should still be able to locate the resources it depends upon.
For example let us asume you have the following project structure:
c:\myproject\project.aip
c:\myproject\resources\myresource.txt
Simply rename the "myproject" folder. project.aip should still be able to locate myresource.txt and it should still be buildable.
You can also look inside the .aip itself using a text editor to see that the paths really are relative.
Gabriel
