harmn1
Trial licensing mode doesn't work under Vista
Dear all
My installer works fine under XP, using your trialware DLL. When I try to run the same installer under Vista, the trialware does not work correctly. The first dialog box (see Vista1.png in the attached ZIP) has no graphics and, more importantly, no 'Try' button. There is no way to try the software without entering a key!
If you click Next, (see Vista2.png) you can enter a key (which does work correctly and will unlock the software), but the dialog still has no graphics, and referes to a 'Continue' buytton which doesn't exist. If you click Back on this dialog (Vista3.png), you can no longer go forward to the registraion key dialog, and are basically stuck with Cancel as the only option.
I have included the XP dialog images in the ZIP as well, for reference.
Is this an issue with the Trial.dll version I'm using? My AI is 7.3, BTW.
Regards
Nick
Trial Problem.zip
Screenshots of dialog boxes
(206.59 KiB) Downloaded 383 times
GabrielBarbu
Re: Trial licensing mode doesn't work under Vista
Please refer to this article which discusses the issue in detail:
http://www.advancedinstaller.com/forums ... ols#p27243
Let me know if it helped.
Gabriel
Gabriel Barbu
Advanced Installer Team
harmn1
Gabriel
I'm now totally confused"! My app doesn't use .NET, or MFC - it's a C++Builder 6 application.. It works fine under XP, so why does it fail under Vista? IT sounds as though you're suggesting that I need a complete different build to make this work on Vista - where should this mysterious 'manifest' (which I've never needed before) go?
harmn1
Gabriel
I've just opened by installer EXE in ResHacker, and found the attached compiled into it (presumably by AI). This looks as though it's the right data, referring to your linked article (the publicKeyToken attribute is correct - it's just been lost off the edge of the screen), but it still doesn't work on Vista.
Any ideas?
Nick
GabrielBarbu
Please send the built msi to support at advancedinstaller dot com so we can further investigate the issue.
Gabriel
Gabriel Barbu
harmn1
Gabriel
If it put a file <appname>.exe.manifest in the same folder as the EXE, it works better - I do at least get a Try button. However, I also get a 'Buy' button, which shouldn't be there (and isn't there on XP), and there are still no graphics. The manifest contains data as shown below (this came from the manifest which AI embeds in my installer). I've also tried modifying the example manifest on the linked page which you referred me to and using that, with the same results.
Nick
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
  <dependency>
    <dependentAssembly>
      <assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls" version="6.0.0.0" processorArchitecture="x86" publicKeyToken="6595b64144ccf1df" language="*">
      </assemblyIdentity>
    </dependentAssembly>
  </dependency>
  <trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
    <security>
      <requestedPrivileges>
        <requestedExecutionLevel level="asInvoker" uiAccess="false">
        </requestedExecutionLevel>
      </requestedPrivileges>
    </security>
  </trustInfo>
  <compatibility xmlns="urn:schemas-microsoft-com:compatibility.v1">
    <application>
      <supportedOS Id="{35138b9a-5d96-4fbd-8e2d-a2440225f93a}"></supportedOS>
      <supportedOS Id="{e2011457-1546-43c5-a5fe-008deee3d3f0}"></supportedOS>
    </application>
  </compatibility>
</assembly>
