leapingdog
Can Not Remove the Program from the Computer
I can not uninstall the program from the target machine. I have tried to uninstall using within the “Add or Remove Programs”. The target machine uses Windows XP SP2.
The program was packaged using Advanced Installer 7.6.
I have listed my observations below. Thanks for your help.
1.) After clicking the ‘Remove’ button a first message box pops up which says
“Please wait while Windows Configures Program”
2.) Then, a second message box pops up which says
“There is a problem with the windows installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.”
3.) The a third message box pops up saying:
“Fatal error during installation”
Re: Can Not Remove the Program from the Computer
This error usually appears when a custom action fails to execute correctly.
The easiest way to force the machine to uninstall it is to use Windows Installer Clean Up tool provided by Microsoft.
Let me know if you have any questions.
leapingdog
Thank you for your response.
I can not install or run Windows Installer Clean Up tool because it is giving me an error:
Installer Insformation
"Internal Error 2907
{121634B3-2f4a-11d3-ADA3-00C04F52DD52}
Is there an overall problem with Windows Operating system now?
Is there an alternate way to uninstall the program? I am in a real bind.
Thanks.
This is a security error, do you have admin rights on that machine?
Please make sure that you run the installation package for Windows Installer CleanUp with "Run as ..." option.
