Emmett_Brown
Unable to extract temp file to a Unicode location
I have encountered a problem while trying to install a package (created by AI 7.6) which has a temporary file which destination path contains Unicode characters. In particular the destination is the Windows Temporary directory but the user name contains Unicode characters so the actual path to %temp% directory is C:\Users\사용자\ AppData\Local\Temp
I attached a screen shot from Process Monitor which was running during the installation.
User name is사용자 (Korean language) but in the picture there is “3?” string instead of a real user name.
This problem does not occur in case of installed files (not temporary).
To reproduce it 2 steps must be followed:
1. It is need to either have one of the Unicode language version of the OS (e.g. Korean, Japanese) or set system locale in Control Panel -> Regional and Language Options -> Administrative tab -> Change system locale... to one of the Unicode languages and reboot
2. Create an user account that username contains a Unicode characters
Then if an attempt to install is made, a temporary file is never extracted to %temp% directory.
Thanks for any help.
Emmett Brown
Re: Unable to extract temp file to a Unicode location
Can you please send us the aip file to support at advancedinstaller dot com so we can further investigate this behavior?
It seems there is a bug in Advanced Installer, i.e. the paths for temporary files don't support Unicode characters.
A future version will surely include this improvement, until then the solution is for you to place the temp file in a per-machine location, like "Common Application Data" folder for example.
Also, to make sure you identify correctly your file I suggest you give to it a stronger name, for example:
script-{some GUID}.vbs
Please let us know if you have any other questions.
