Metall4You
ReInstall after Database upgrade
Hi
After a copy from a newer Database as that is installed in the installdirectory, the installer setup begins to run and abort it.
Disabled modifay ist set to true in the settings...............any idee
Pls help, thanks
GabrielBarbu
Re: ReInstall after Database upgrade
I am not sure I understand your issue.
Could you please describe this in more detail?
Gabriel
Gabriel Barbu
Advanced Installer Team
Metall4You
Hi gabriel
sorry my english
When I copy a newer Database-mdb or file in the app directory after install, the setup restarts and abort, see picture. in the settings is disabled modify = true
After install, i dont want to modify ur upgrade the setup.
best regards
Ramon
EasyMet Install.JPG (18.52 KiB) Viewed 6840 times
Metall4You
Hi
When i download a newer .exe File in the ProgrammDir, the installer begins automaticly repair the installer package. See the picture below.
How can disable this?
pls confirm
Thanks Ramon
GabrielBarbu
About self healing (automatic repair)
Hi Ramon,
This behavior is encountered because you modified/deleted/replaced a file that was registered with Windows Installer. Windows Installer does not recognize the new file so it triggers a self-repairing mechanism.
To prevent this, please make sure the shortcut you are creating to your application is not marked as Advertised by right clicking it in Advanced Installer and selecting Properties. Uncheck the option for Advertised shortcut. For more details, please consult our guide on the self-healing behavior.
Gabriel
Gabriel Barbu
Metall4You
Hello and good morning
in the organization have everything set up as described, but after the download of the exe-file an entry written to the registry, the repair install begins still anew. I do not know more, pls help
thanks Ramon
GabrielBarbu
Hi Ramon,
Please send your .aip project file to support at advancedinstaller dot com so I can take a look at it.
Gabriel
Gabriel Barbu
