andy.garratt
MuiCache Registry Settings
Can someone tell me what the 'Local Settings\MuiCache' registry settings are which are set in the MSI installers created by Advanced Installer? There seems to be lots of the for all sorts such as :
XPS Viewer
Windows Fax and Scan
Windows DVD Maker
Which are nothing to do with my application.
Cheers
ANdy
Cosmin
Re: MuiCache Registry Settings
Please note that these registry entries are not created automatically by Advanced Installer. Are you using the Repackager? If so, perhaps they were captured during the repackage process. In this case you can delete them manually from the "Registry" page or modify the repackager filters to ignore them.
Cosmin
andy.garratt
These do not show in Advanced Installer, only when you view the resulant msi in InstED
GabrielBarbu
Hi Andy,
Please send your .aip project file to support at advancedinstaller dot com so we can investigate. Also, you did not answer Cosmin's question: did you use the Repackager to capture the installation? Is the .aip project file a result of that process?
Gabriel
Gabriel Barbu
Advanced Installer Team
andy.garratt
Hi Gabriel,
I answered Cosmin's question indirectly as the suggestion was to remove them from the Registry page, as you can see from the screen shots they do not show in the registry page. This is not made using the repackager :)
Andy
Hi Andy,
Can you please send us the aip file to support at advancedinstaller dot com so we can investigate, and the MSI package if possible.
andy.garratt
Please ignore this, I was being stupid, they are visible in the registry settings :)
Andy
