mtayyab
Modify text on Prerequisite screen
I am using Advanced Install 7.3.1 and I want to change the text on Prerequisites screen. The default text is too long and on higher DPI it crosses the image downwards.
Following is the text on prerequisites screen that I want to modify,
"These programs are needed for the application to run. Click on the check box next to a prerequisite to select it for install or to skip it"
I have also attached the snapshot of the related screen.
Please advice. I also need to change the same text in other languages.
--Tayyab
Snap shot of Prereq Screen
Re: Modify text on Prerequisite screen
I'm afraid this is not possible from Advanced Installer.
This is a built-in resource from the boostrapper (the EXE) and cannot be edited in our application, only MSI dialogs can be edited using the Dialog Editor.
Please let us know if you have other questions.
