maxt
Prerequisite - again
G'day
Would you please run me throught the Prerequisite sequence and steps.
Am I correct in assuming that the product install on the clients machine has not been performed at the Prerequisite stage?
Therefore destination folders in Program Files or elsewhere have not yet been created in the clients machine.
I have three 3rd party .EXE install files to be executed as Prerequisites set up in the Files and Folders step as set in my own computer.
I am confused about the values to put into the Prerequisite textboxes:
Location
File Path
Command Line
File To Search
for each of these.
Why does it need to search and where is the 3rd party .EXE on the clients machine at this stage?
When testing the install (also on my machine at this stage), the Prequisite screen appears, but on Next I get:
After launching all packages some required prerequisites are still missing.
After Back I get:
Version: Required: 1.0 or higher. Found: nothing
Action: Install
Thanx
Max
ciprian
Hi Max,
Prerequisites are programs that must be installed on the target computer before your package is. If a perquisite in already present on the target machine it's installation is skipped.
In order to tell whether a perquisite is already deployed a search criteria must be specified. It could be a file version or a registry entry. In the "File to Find" field you must specify the location of the file that must be present on the target machine in order for the perquisite to be considered installed.
In the "Location" field you can choose where the prerequisite file resides. There are several options File in Package, URL and Open Site. In the "File Path" field is specified the location of the file. It could be a location from your computer or an URL.
In the "Command Line" field you could specify a command line that will be used when the perquisite is installed.
For more details on how to set up a perquisite please see the Advanced Installer help pages or visit the following URL location:
http://www.advancedinstaller.com/user-g ... sites.html
The reason for which you are getting those messages, after installing the prerequisites, is that didn't specified a search criteria when you set up the perquisites.
Please let me know if you have any more questions.
Ciprian
Ciprian Burca
Advanced Installer Team
Kashif Iqbal
Re: Prerequisite - again
Dear Team,
Kindly guide me how can we remove required 1.1 or above in pre requisite
Please find the attached screenshot.
I am waiting for your response.
Thanks & Regards,
Kashif Iqbal
Kashif Iqbal
Dear Team,
Thanks & Regards,
Kashif Iqbal
Kashif Iqbal
Dear Team,
Waiting for your help to sort out the problem
Please guide me ASAP.
Thanks & Regards,
Kashif Iqbal
Kashif Iqbal
Reminder :(
Hello Kashif,
Unfortunately, I am afraid that field can not be removed from the dialog nor it can be modified (e.g. so it shows nothing).
Pretty much all the logic from that dialog is handled by our EXE bootstrapper internally.
Please let me know if you have any other questions and I will gladly assist.
