Nate
How do prerequisites work with multiple versions of Windows?
I need to ensure that Windows Installer 4.5 is available.
I understand that I can add it as a prerequisite, but which one should I add? Or should I add all of them? My options are "WI for Windows XP x86", "WI for Windows Server 2003 X86", "WI for Vista/Server 2008 x86" and so on.
There seems to be no way to restrict them to the correct OS version. If I add "WI for Windows XP x86" and choose an Install Condition of "Windows NT From: Windows XP Service Pack 2" then wouldn't that also install on Windows Server 2003 and Vista? That seems bad: each OS should get it's own WI 4.5 installer setup.
Nate
Re: How do prerequisites work with multiple versions of Windows?
To answer my own question: the order of the prerequisites matters. I arranged them so those for the newer operating systems would install first. As a result, by the time the prerequisite that matches XP or higher is reached on a Vista machine, the prerequisite will already have been installed.
