davidnewcomb
Changing the background colour of install screens
I'm trying to update the look and feel of the installer. I have updated the banner, watermark images and changed the font colour to be white.
Is there anyway to change the bottom of the screen area (where the buttons are) because it is still showing grey (pic 1). Is it possible to change the colours of the buttons.
The other problem is that the banner is placed at the top of all the other screens but there doesn't seem to be anything I can change to affect the body of the other screens so they are showing as grey too (pic 2).
Currently, I am not using the enhanced interface. The documentation mentions a lot of the benefits of using the Enhanced Interface Installer, but it doesn't mention what I lose when I use it. Perhaps you could clarify this.
All other screens showing banner
Beginning screen showing new watermark
Re: Changing the background colour of install screens
For this you can try using a simple bitmap control. Add it over that screen area and set the desired source file.
You cannot change the colour directly, but you can change the button type to icon or bitmap and set the desired source file in this case too.
Using Enhanced UI will give you a lot more editing options, as well as the possibility to use new predefined themes with a much more attractive look.
Enhanced UI also suppose that you always use an EXE file as the main setup file, which in some cases can be considered a drawback. The purpose of the feature is to give you access to new
options, not to put new limits.
davidnewcomb
Done that which resulted in the need to change the background colour of everything above it - see (pic 3). The text style only lets you change the font's colour and not the background colour. Another problem is that after adding the background bitmap to the page, it only changed that one page. All the others looked the same as before, so I would have to make the changes to all pages. Is there anyway to change the background of the underlying 'thing' so that changes are reflected on all screens?
I suppose it's really a bug in that the text should have a transparent background and not a grey one so that you can put things behind it - otherwise there's almost no point to having UI widget ordering.
background image
background image
GabrielBarbu
Hello David,
The issue stems from the fact Windows Installer does not support controls with transparent backgrounds. To prevent this, you can use our Enhanced User Interface. To enable it, go to Themes page->Settings tab and set the "Use Enhanced User Interface" option to Always. Note that this will make your installer an .exe instead of an .msi.
Gabriel
Gabriel Barbu
Advanced Installer Team
