toddpatt
hyperlinks in eula.rtf not clickable on LicenseAgreementDlg
G'day,
I'm using AI 7.7 build 28804
I have a EULA in valid RTF format that I am showing on the LicenseAgreementDlg. There are some hyperlinks within the EULA. When the EULA is rendered on the LicenseAgreementDlg, the hyperlinks are displayed inside <angle-brackets> and are not clickable. I also tried shift-click and ctrl-click (MsWord uses this key-combo) but neither works.
LicenseAgreementDlg - eula with hyperlink.JPG (24.47 KiB) Viewed 8667 times
Another user noted this same problem in this forum post, but no definitive answer was given as to whether hyperlinks in the EULA could be made clickable.
I checked the MSDN documentation regarding the LicenseAgreement Dialog. It discusses the "ScrollableText Control" (not sure if this is the same as AI's "Scrollable Edit") and the "Text" attribute, but doesn't discuss the details of RTF rendering.
Is it possible to make hyperlinks clickable inside the "Scrollable Edit" control on the LicenseAgreementDlg? I have tried both with and without the "Enhanced User Interface".
Thanks for your help,
-Todd
Re: hyperlinks in eula.rtf not clickable on LicenseAgreement
Hi Todd,
I've done a small search on MSDN and unfortunately found that you cannot insert hyperlinks in your EULA.
Here is the article confirming this information.
toddpatt
Re: hyperlinks in eula.rtf not clickable on LicenseAgreementDlg
Thanks for finding that article, Bogdan. It's disappointing, but at least now I have a definitive answer.
Much appreciated,
-Todd
den
I have question related to the current topic.
Hyperlinks in eula.rtf appears inside angle brackets (<link text>), is it possible not to display them?
Den.
CiprianComsa
Hi Den,
I have made a research and unfortunately I haven't found a method to eliminate angle brackets from a hyperlink.
I am recommending you to try the Enterprise version which contains a component of HTML Host control from Dialog editor page.
The HTML Host control displays a HTML page from a given URL or a local file. Using that control, you will be able to personalize the content of the dialog using HTML markup language.
Ciprian
__________________________________________________________________________________________________________________________________________________
Ciprian Comsa
Advanced Installer Team
Ciprian Comsa - Advanced Installer Team
