drivard
ErrorDlg is not properly translating the pre-req disp name
AI Enterprise 7.5.1
For one of our pre-requisites, we use a property for the Pre-Requisite Display Name.
If an error occurs during the pre-req install, the errordlg appears, but instead of the property value, we see the property name.
So, instead of "Acme Pre-Requisite", we instead see [|ACME_PREREQ_PACKAGE].
Is this a known bug? I looked the the post-7.5.1 release history and didn't see it in the fixed list.
Re: ErrorDlg is not properly translating the pre-req disp name
Please note that the display name of a prerequisite is a pseudo-formatted field, this means that it is resolved at build-time, not run-time.
Please make sure the properties you are using in pseudo-formatted fields have a value set in the Install Parameters page.
drivard
Hi Bogdan,
I understand how it works. I am reporting that the error dialog is not properly resolving the property at build time.
The property is appearing correctly in the "Display Name" column of the Software Prerequisites page, which shows that the property exists and has a value.
Dennis
Hi Dennis,
It seems this is a bug in our application. Thank you for bringing it to our attention, a fix should be included in our future version.
