bccc
Prevent custom action execution on upgrade install
I am new to Advanced Installer and am currently not having any success with the upgrade feature. I have automatically upgrade older product versions selected and uninstall old version first and then install new version. I also have a custom action set to execute on install. During the upgrade process I would like to prevent this custom action from executing if an older version has been upgraded. I only want it to execute if this is a clean install. The properties of the custom action are: synchronous execution, check return code; deferred with no impersonation; always execute. The current execution condition is NOT installed, but I have also tried NOT installed AND NOT UPGRADINGPRODUCTCODE. I assume my execution condition is not correct and would appreciate any guidance on how to achieve this result.
Thanks!
CiprianComsa
Re: Prevent custom action execution on upgrade install
Hi and welcome to Advanced Installer Forum,
You typed the wrong condition. Please make sure you typed the condition like this: "NOT Installed AND NOT UPGRADINGPRODUCTCODE".
Note the capital 'i' in 'Installed'.
Ciprian Comsa
__________________________________________________________________________________________________________________________________________________
Ciprian Comsa
Advanced Installer Team
Ciprian Comsa - Advanced Installer Team
bccc
That was a typo in my post. It is in the format you suggest in my project. However, my custom action continues to execute when I perform an upgrade. Is this the correct execution condition to accomplish what I am looking for? Is there something else I am missing that I should investigate?
Thanks for your response!
CiprianComsa
Can you please try using the following condition:
NOT Installed and NOT OLDPRODUCTS
The property OLDPRODUCTS contains a list with the Product Codes of the older versions of your installation package. This property is set only in a package which upgrades another package.
The UPGRADINGPRODUCTCODE property is set in the package that is being uninstalled(upgraded) not in the new one.
Ciprian
Ciprian Comsa
bccc
That worked! Thanks for your help.
nitind
Below condition NOT worked for me.
I want to restrict custom action to Run in Upgrade process.
This post is pretty old.
We have added predefined support for your task.
In order to achieve that, you can go to "Custom Actions" page --> select your custom action --> under "Execution Stage Condition" press on the "Show upgrade options" and there you can uncheck the "Upgrade" option which is checked by default.
nitind
Thanks for quick response.!
PFA, I already did that, but this is also NOT worked for me.
This could happen if the old version of your product has a different UpgradeCode. In this case the new product version installation will not automatically upgrade your older version.
If this is the case you could either set the same UpgradeCode for your new product version or create a search to look for the older product version and use the search property to condition your custom action too.
