srishmawi
Encoding with installed SQL query
I run SQL script with the installer which first creates the database then execute the sql , it contains characters that needs utf8 enconding. The installation finishes fine and the database is created, but these characters does not appear correctly. However, executing the sql using any other tool makes the characters appear correctly.
How to fix it ?
thanks.
CiprianComsa
Re: Encoding with installed SQL query
This behavior may be encountered if you don't have "UTF-8 codepage" option selected. Go to Media page -> Msi tab and check if the "UTF-8 codepage" option is selected.
Note: the SQL Script file needs to be encoded as UTF8 with BOM in order to be used as an Unicode script.
Ciprian
_________________________________________________________________________________________________________________________________________________
Ciprian Comsa
Advanced Installer Team
Ciprian Comsa - Advanced Installer Team
SZLMCL
I have also an sql script file that contains unicode characters. I set the UTF8 option in Database encoding tab and set my file encoding to UTF8 with BOM, but the installation failed.
The error throws at this line, but I not see any syntax error:
If I copy-paste the script code to SQL Management Studio, the script executes successfully.
Can you help me please, what is the problem?
Thank you!
I checked the SQL file in Notepad++ and I noticed that the character between the "RETURN" and "FileTableRootPath()" is not actually a space character (please see a diff in the image below).
Can you please remove that character, then add a space character, save the SQL script and test it again?
Missing Space.png (2.26 KiB) Viewed 8590 times
SZLMCL
Thank you for the suggestion.
I have more than 300 of this white-char in my script. I dont know what was the origin of this char (char code 194+160). After I replace all with space char, the script working well!
For some reason the SQL Management Studio can handle this char, but the external scripts cannot.
Thanks for help!
BR, László
You are always welcome, László!
We are glad everything works as expected now.
