xnejx
Progress bar color change?
Hi
Is there a way to change the progress bar color from green to something else in the ProgressDlg?
Thank you,
CiprianComsa
Re: Progress bar color change?
You can try to change color of progress bar using a HTML host control. You can create a custom HTML control which displays your progress bar.
Ciprian
__________________________________________________________________________________________________________________________________________________
Ciprian Comsa
Advanced Installer Team
Ciprian Comsa - Advanced Installer Team
xnejx
Thank you.
Another way to change the color of the progress bar is to follow the steps below:
- remove the already existent progress bar
- add a new "Styled Progress Bar" control and resize it as you please
- add a PNG image with the desired colors for that progress bar, by selecting it in the "Image Path" field from the "Properties" pane
- the progress bar image should be designed as the one attached to this post, where the first color is the background of the dialog and the second one is the color of the progress bar
- build and run the project
