hovhannest
Localization of 'Update Options' dialog
Hello
Is there a way to localize the 'Update Options' dialog?
I'm using Advanced Installer 7.2.1
Thank you in advance.
H
Re: Localization of 'Update Options' dialog
Hi Hovhannes,
Are you referring to the dialog "Checking for Updates" or "Updates found ..." ? If so, these dialogs are already localized, they use the original language of the OS from the machine on which the updater is running.
If not, please give me more details, maybe a screen-shot.
rusticdog
Bogdan wrote:Hi Hovhannes,
Hope you don't mind the slight thread hijack Bogdan, but the dialog 'Your software is up to date' should have the OK button in caps, not Ok
Excuse the ugly font, I was also testing changing my System Font :)
Not a problem, thank you for bringing this to our attention. The text from the button will be changed in future version of Advanced Installer.
Return to “Feature Requests”
