razvan
Error in the "configure .net assemblies in your packageform"
It seems I'm having a hard time making your product work. In the wizard that creates a new project, if I press configure I get the error from attachment
Cosmin
Re: Error in the "configure .net assemblies in your packageform"
This is caused by a bug in Advanced Installer. Invalid assemblies are not handled correctly, so an exception is thrown. A bugfix will be included in the next release. Please make sure that you are using valid Windows assemblies (for example they all have a PublicKeyToken attribute).
Cosmin
razvan
what about 3rd party assemblies that need to be included in my application?
Cosmin
You can add them as regular files in the "Files and Folders" page. Assemblies page should be used only for assemblies you want to install in the GAC.
Cosmin
razvan
Hi Cosmin,
The problem is that by default Advanced Installer installs your dll's in GAC. I believe this is wrong, by default it should treat my assemblies as normal files and it should deploy them like any other file. After I learned how ai works, I understand now thy it wasn't deploying my assemblies, but however it would be more intuitively to work as I expect. I'm just trying to help.
Razvan
