Using AI 7.7:
I added a Custom Action in "InstallExecuteSequence"->"Rollback" for my tests that pops-up a MessageBox without any conditions and is configured to be: "Rollback with no impersonation".
Now I try to make this MessageBox appear, but nothing causes it to pop-up.
I tried installing the msi, and at the welcome page pressing "cancel": but the only thing that happened is that the installation ends with "The <my program> Setup Wizard was interrupted" and then you press the "finish" button.
I tried pressing the "cancel" button after I finished with all the dialog windows (== after finally pressing: "install"), but that didn't work either (I got to the same ending page like I mentioned above).
I even tried your custom action "Error" which after showing an error message it fails the installation. But that also didn't cause my custom action in the rollback to be called, but instead ended with a dialog which is a little different then before: "The <my program> Setp Wizard ended prematurely".
So what I want to do is this:
1. Have a "rollback" custom action that's called if installation fails.
2. How can this be done? (as explained above, I tried what seemed to be logical: and create my custom action under "Rollback" with "Rollback with no impersonation": but it was NEVER called...)
Many thanks, Dashut.
