hmxchooch
'Repair' issues
Issue #1: When I run repair on my app from the control panel (Windows XP) I am seeing a weird graphical glitch. I'm using the default "graphite" theme with no modifications to this screen. This does NOT happen when running from setup.exe. (see attached image)
Issue #2: When I run repair on my app from either re-running the setup.exe, OR from control panel, the last screen it gives me before exiting the installer is "uninstall is complete". Except... it was a repair, not an uninstall. This must be an issue with the graphite theme?
I'm on AI 7.7, and our license has run out. Are these fixed in 8.0.1?
mihai.petcu
Re: 'Repair' issues
The graphite theme uses "Enhanced UI". To activate this feature in the maintenance mode simply navigate to the "Themes" page, go to the "Settings" tab and select the "Always(install,uninstall and maintenance)" option.
Please note that the same "ExitDialog" is used for for maintenance, patch and first time install. This is a Windows Installer standard.
Starting with the enterprise license and project type you will have conditional edit access in the Dialogs page and with this feature you can accomplish showing a different message in the "ExitDialog" on maintenance mode.
hmxchooch
Re: 'Repair' issues
I was already using this option. Again - this glitch only happens when I go to the maintenance screen from the Windows XP Control Panel add/remove programs UI, and does *not* happen when I repair by running setup.exe in maintenance mode. I imagine there must be a bug where somewhere...
It might be standard to use ExitDialog at the end but it shouldn't tell a user they've uninstalled an app when they have just hit repair, right? I mean, that has to be a bug. We do have an enterprise license and project type so I will take a look at the conditional text you've suggested, thanks.
mihai.petcu
Re: 'Repair' issues
In the "Product Details" page, please make sure you have the "Override Windows Installer programs list entry" option checked. The "Disable Repair" option will be checked automatically because only native Windows Installer "Add or Remove Programs" entries can use a [ Repair ] button.
I have passed this bug to the development team and the fix will be available in a future version. Meanwhile, here is the tutorial from our user guide that describes the steps to accomplish what you need.
Best,
