Kim.Martin
Install components to UNC path
We have an installer that deploys a database.
I have changed it (as per a user request) so that they can specify their own location for this component. However, some users need to deploy this large (3GB) database directly to a network location using a UNC path.
While it works for local paths, in all cases the UNC path installation fails (even if the path is actually local). The user does have admin permissions; I've tried using browse, setting directly, removing the extra \ from the end and lots more.
The message is "Could not access network location \\lsrukmatwxx0123\Shared\fred\\." (or similar).
It always seems to end in \\.
Any ideas what might be causing this?
mihai.petcu
Re: Install components to UNC path
Please try to set your network folder with full control permissions to everyone. This should do the trick.
Kim.Martin
I did try this, but it doesn't seem to be working.
I've attached some screenshots of the messages:
1. Share permissions:
2. Selecting the path (blanked product names since it's not released yet!):
3. Error message:
mihai.petcu
Please send us the .AIP (project) and a verbose log of the installation to support at advancedinstaller dot com so we can help you investigate.
Hi Martin,
This behavior is caused by a bug in Advanced Installer. Thank you for bringing this to our attention, a fix will be available in a future version.
Until the fix is available the only solution to install it to an UNC path is to disable the Enhanced User Interface from the Themes page, Settings tab. Select "Never" radio button.
Kim.Martin
Thank you.
I could not see this fix listed in the release notes, although I may have missed it, but it does now seem to be installing correctly under Advanced Installer 8.1 to UNC paths.
