IB85lb
welcome message problem
i select my welcome text.rtf in bootstarapper in prerequisite page it works normal when i have one language but one i have more one language
it gave me error message
Exception -Reason :failed to read into text for boot strapper from file "c:\\...............\bootstraper option.Intro Text path.Global Options"
Detail: The system cannot find the Specified make sure you localized correctly the path for boot strapper intro text.
if i want to edit the " welcome prerequisites wizard " that begin the installer .
how we solve it any help ?????????
Best Regards
IB85lb
mihai.petcu
Re: welcome message problem
You need to modify the paths in the dictionary generated by Advanced Installer after the adding extra languages, with the paths of your localized text.rtf.
Here is the tutorial from our user guide that has similar steps for localizing the EULA text.
Also please note that you cannot edit the welcome dialog from Advanced Installer.
IB85lb
Hello
Thanks for ur help but ur way didn't work still give me the same message .
in the tutorial that give me it about Eula and read me there is some thing we should use it in Dialog page but what i am asking about it the Welcome text that appear when we use global prerequisites .
i make as the tutorial said but i have some differenet between eula .ail file and my ail file
eula.ail
<ENTRY id="AgreementText">
    <STRING lang="en" value="C:\My Installation Project\EULA English.rtf"/>
    <STRING lang="fr" value="EULA French.rtf"/>
    <STRING lang="de" value="EULA German.rtf"/>
  </ENTRY>
welcome.ail
<ENTRY id="Bootstrapper options.Intro Text path.Global Options">
    <STRING lang="fr" value=""/>
    <STRING lang="de" value=""/>
  </ENTRY>
but there is something i didn't under stand
the Eula Id :
AgreementTex
but
welcome ID:
what is the problem ???????????????//
mihai.petcu
The error is thrown because in the welcome.ail file you need to provide a value for each language entry. This is the actual purpose of localizing the welcome text. Here is an example of what I mean:
        <STRING lang="fr" value="C:\My Installation Project\EULA French.rtf"/>
        <STRING lang="de" value="C:\My Installation Project\EULA German.rtf"/>
      </ENTRY>
This is an unique identifier you can modify if you go in the "Prerequisites" page, right click in the file path field of the "Custom welcome text in Information page" and select "Localization..." from the context menu.
The AgreementText ID refers to the editable control name inside the LicenseAgreementDlg dialog which loads the rtf file.
IB85lb
hello
thanks for ur help its works :D
but about the
didn't work because i didn't found properties if u can give me an snapshot of how u make .
Best Regards
IB85lb
mihai.petcu
This context menu can be accessed from the "Prerequisites" page when you right click in the "Custom welcome text in Information page" file path text field (only if you have more than one languages selected in the "Translations" page) :
IB85lb
thanks it works
