tommobb
Another Version of the product is already installed
How do I prevent the message that reads "Another version of this product is already installed"?
I am updating the version from the command line by running
AdvancedInstaller.com /edit Installer.aip /SetVersion 1.0.5.x
The documentation says "go to the "Product Details" page and increase the version of the package" but I can't find this option?
Thanks!
Screen shot of message
Re: Another Version of the product is already installed
This error message appears because the product code remained the same for the new package. Usually, when you change the version a new product code is generated.
However, Windows Installer ignores the forth field of the version, only if you change one of the first three groups from the version a new product code is generated.
You can also change the produce code manually from "Project -> Options -> Project IDs" tab.
When you open Advanced Installer the Product Details page is usually found in left side menu, upper side. You can also access it using the menu "Installation". In this page you will find a field called "Product Version".
Please let me know if you have any questions.
