cos
Registry value persistence
I need my installer to write a registry value only if that value doesn't exist. Also on uninstall that value should not be removed. How can I do that?
Regards
mihai.petcu
Re: Registry value persistence
You can add a search for that registry value from the Search page and then use the search's name to condition the registry's component from the Organization page. To avoid the value from being removed on uninstall you should also mark its component as "Permanent".
