Koen
File overwrite
My advanced installer contains a settings file for my program. It's placed in a certain folder by use of a search. If this file already exists the installer should not overwrite it. It should skip this file. But instead the file is overwritten. How can I alter my project to install the file if it doesn't exist and to skip the installation of that file if it does exist?
Koen
mihai.petcu
Re: File overwrite
Hi Koen,
You can add a file search in the Search page to check if the file exists on the target machine. You can then use the search's name in the condition field of your file's component in the Organization page.
Return to “Feature Requests”
