Keymaster
Unhandled Exception Problem
Hello I am getting an Unhandled Exception error when trying to import repackage installation the program seems to work except for when I try and do this project, I am able to chose the exe and the settings but when it goes to start the capture is when I get the error I have provided an attachment of the error I get. I am running Windows 7 64 bit.
mihai.petcu
Re: Unhandled Exception Problem
Hello and welcome to Advanced Installer Forums,
Please try to reproduce this behavior on other machines and also send us the URL of the setup you are trying to repackage so we can assist you in the meantime.
Keymaster
Ok I was able to reproduce this error 3 times on different machines. as far as the exe I am trying to repackage I have tried multiple setup packages all with the same error. I was able to use an older version 6.2 of Advanced installer and had no problems using the Repackage program. all my machines I reproduced this error on are running Windows 7 x64, sorry I dont have any other computers with another version of OS to test.
mihai.petcu
Do you have UAC enabled on your Windows 7 machines? Also, are you running the repackager with elevated privileges?
Please send us an URL to the setup you are trying to repackage.
