wpa1160
ACCESS_VIOLATION (0xc0000005) after installation capture
I receive a [READ OPERATION] ACCESS_VIOLATION (0xc0000005) after capturing an installation.
Right after clicking on "Finish" on the "You have successfully completed the Repackager Wizard" dialog the error occurs.
Advanced Installer does not quit and can be used as usual but I'm not sure if everything is included.
The capture itself is executed with the default profile.
OS is Windows 7 (x64), Software being captured is SolidWorks eDrawings 2011 (x64) 11.2.0.113
Same error (slightly similar message) occurs when using Vista (x64)
mihai.petcu
Re: ACCESS_VIOLATION (0xc0000005) after installation capture
Hello and welcome to the Advanced Installer Forums,
Can you please give us the URL of the setup you are trying to repackage so we can reproduce this on our machines too?
wpa1160
Sure, but there's no direct download URL available. Please perform the following steps in order to download the executable:
a) URL = http://www.solidworks.com/sw/support/eD ... type=64bit
b) Select option "eDrawings Viewer only" and click on "Next"
c) Click on Download (leave other options unmodified)
d) Confirm "Export Eligibility Requirements"
e) Download
Thanks!
mihai.petcu
I have tested the package on a Windows 7 x64 machine and I cannot reproduce the issue.
Please send us the RPK file generated by the repackager to support at advancedinstaller dot com so we can investigate it.
