testarosa
auto updater system cannot find the path specified
I originally released and installation including an auto updater that worked fine and checks the server with no problem, I'm creating my first upgrade to that original installation now.
When I created the updated msi file, I configured the auto updater just like I did the first time, modified the updates.txt, put it on the server with the new udpated msi file. The original auto updater from the first installation finds the updated file. However, people who don't have that original install installed have to pull the entire new update (full install) that includes the new auto updater from this 1st update, also when this new update runs it overwrites the original auto updater, therefore the auto updater on this 1st upgrade MUST run correctly as it "replaces" the updater from my first installation. I was getting an MD5 error so I eliminated verifying ID on this auto updater, that's the only significant change I made between the first updater and this one. Now, this auto updater checks the server "please wait" - so it's getting to the server, then it spits back "system cannot find the path specified". For the life of me I cannot figure out where it is failing. Everything seems to be in it's place. Please see attached files.
Can you set me in the right direction?
Thanks!
mihai.petcu
Re: auto updater system cannot find the path specified
Please note that for your updates to work properly, you need to modify the updates configuration project(not the file itself) by adding all the updates, build it and place the generated configuration file on the server. Here is a tutorial from our user guide that can help you.
If you are having trouble understanding or creating an auto update strategy, please follow our auto update tutorial before implementing the functionality in your application.
If the problem persists, please send all the .AIPs(projects) to support at advancedinstaller dot com so we can investigate them.
testarosa
Thanks! I rebuilt it again to the letter this morning. Same result, once it's installed the updater.lnk gives "system cannot find the path specified".
I sent the config files via email.
Appreciate your help. You have excellent support.
The error appears because you have set an incorrect path for the field "Downloads Folder", from Updates page, in version 6.2.1 of your project. This field must be set to a valid path, for example:
C:\[ProductName]\downloads\
or,
[APPDIR]downloads\
This should fix the problem.
