rsiddhartht
Getting error while trying to create a website
I have developed an installer which creates a new website and a virtual directory under it. Its working fine with Windows Server 2003 but while installing in Windows Server 2008 I am getting an error ( a snapshot of the error is attached). I doubt it is realated to IIS 7. Kindly let me know the solution of the above problem.
Siddharth
(I am using Advance Installer 6.3)
Installer Error Message
octavian.vasilovici
Re: Getting error while trying to create a website
Hi Siddharth,
This error is generated by Windows Installer when it tries to start up the Web Site. It can be translated as:
"Failed to start the Web Site since the port 5021 is already in use". This means that a web site using the port 5021 is already started and running on the machine.
I suggest you try installing the package on another clean machine with the same specifications.
If the error persist please send us the installation LOG file and the project AIP to support at advancedinstaller dot com.
Best Regards,
Octavian
_______________________________________________________________________________________________________________________________________________
Octavian Vasilovici
Advanced Installer Team
Octavian Vasilovici - Advanced Installer Team
rsiddhartht
Hi Octavian,
Thanks for the solution. It worked when I installed in fresh machine.
Siddharth
