hi, i just wanna know if is possible to edit the aip project file automatically ?
Because i want to change the product code and the product version with a batch file or a java class.
Why do you need to change the product code and the product version with a batch file?
However you can change the product version of a project with the use of a AI's command line options. Also you can change the value of a property. The product/upgrade code is given by the roductCode/UpgradeCode property in the AIP file.
To view what command lines are available in AI please take a look at this link:
http://www.advancedinstaller.com/user-g ... iting.html
Gigi
________________
Gheorghe Rada
Advanced Installer Team
