I'm using AI 7.7 build 28804, so you may have already changed this, but just in case:
When I go to the Install Parameters page, the focus is on the Application Folder box. This is a Combo box, so turning the scroll wheel on my mouse changes its value. If I inadvertently turn the scroll wheel, for example if I try to scroll through the left panel without clicking on it first, I have no way of knowing what the value was, and I can't undo the change. What's worse is that I may not notice that I've made the change. If I have defined my own Application Folder path, as opposed to using one of the four pre-defined paths, it will disappear from the list once the project has been closed and re-opened. I've been affected by this a few times and it can be very difficult to debug.
Cheers, Arthur
